tie rods time
...I've had some issues of intermittent shimmy in the steering - pretty severe, like I'm getting a flat. Stop the car and drive off and it's perfectly fine for weeks at a time. Full story is here:
https://rennlist.com/forums/993-foru...ior-95-c4.html
In sum, tie rods seems like the most likely culprit so I'm going after those. Some questions -
1) I'll replace 2, 3, and 5, both sides. Should I replace 13 ($21.25ea at Pelican)?
2) Any tips that I won't find in the DIY?
Many thanks.
Many thanks.
Before replacing anything, I would jack up the front end and check everthing for torque if it's bolted - and for excessive play in the tie rods , wheel bearings, and dare I say, wheel nuts.
It takes two to check tie rods, one to wiggle the wheel at 3 & 9 o'clock - and one to lay two fingers & thumb lightly across either joint: any wear can easily be felt ..... and confirm your plan of R&R.
RL Technical Advisor
Both,........
On a side note, my preference is the GT-2 EVO inners which are spherical bearings (ala 930 tie-rods) but one cannot buy them individually, just as part of the whole darned tie-rod assembly.
One more question (2 parts) - if I make careful measurements of the original rods, can I get away without an alignment? If not, it's just toe-in yes?
Yup-checked for play or loose bolts early on. And torqued the lug nuts myself, two sets of wheels. But I didn't check the rods exactly like you say with help from a friend - thank you - I'll give it a try.
