993 Forum 1995-1998
RS Flywheel Torque Value
Old May 19, 2009 | 09:11 AM
North Coast Cab's Avatar
North Coast Cab
Default RS Flywheel Torque Value
Can't find reference in my Workshop Manual. Anyone know?
Old May 19, 2009 | 09:54 AM
viperbob's Avatar
viperbob
Former Vendor
63 lb-ft. Also use some Locktite on the threads.
Old May 19, 2009 | 10:56 AM
North Coast Cab
Thanks Bob.
One more. I have the disc installed along with the PP, but I didn;t like the installation. The disc would only fit with the "thicker" inner portion towards the flywheel. The PP bolts were not long enough to grab the flywhlle, so I had to use a couple of olonger ones to pull it in and then install the PP bolts.
Does that sound right?
Old May 19, 2009 | 11:03 AM
viperbob's Avatar
viperbob
Former Vendor
Correct. The spring pack goes into the recess in the flywheel. Did you use new PP bolts? You should be using N014 715 3 with the RS setup. Also, how did you install the starter ring gear? The recess on it goes towards the PP (flat side towrds the flywheel).
Old May 19, 2009 | 11:12 AM
North Coast Cab
Covered all of that.
Thanks for the help, been a longtime since I drove this car and she's going back in tomorrow.
Old May 19, 2009 | 11:14 AM
viperbob's Avatar
viperbob
Former Vendor
Cool. You'll love the LWF. Single biggest motor type performance improvement you can do to a 993 for the money...
Old May 19, 2009 | 12:02 PM
Mike J's Avatar
Mike J
Bob confirmed for me the orientation when I put mine together as well...thanks Bob!
I like the feel of the RS clutch, but also the engineer in me likes the simplicity...those DMF's are just too complicated...and heavy! My god, when I lifted mine off the engine, I was suprised by its weight...
Cheers,
Mike
Old May 19, 2009 | 05:12 PM
Van1's Avatar
Van1
I recently did a LWF and really like it. I did not use locktite on any of the bolts. There didn't seem to be any on the factory bolts I took off.
Old May 19, 2009 | 05:21 PM
viperbob's Avatar
viperbob
Former Vendor
There is no locktite on the factory bolts. But seeing as the assembly is spinning a LOT faster now with the LWF, a little Loctite is good insurance....
Old May 19, 2009 | 09:55 PM
North Coast Cab
Yeah, my motor guy insists on it on every car. Tighten them all to torque spec and then back them out individually and hit with some LT.
Old May 19, 2009 | 10:45 PM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
+1 even though the loctite does modify the torque value.
By all rights the torque spec for the RS flywheel and the dumbass flywheel should differ by virtue of their length differences.
