skewed fan pulley
Removed the A/C belt as fan is getting close to touching on right side. Viewing down on the pulleys it is obvious that the alternator pulley is skewed at a slight angle from the crank pulley. No obvious play in pulley. No bearing noise.
It appears as if the whole housing is malformed allowing the fan to drift to one side. High belt pressure over the years to blame?
Could selectively tightening the alternator fastenings within the housing realign the unit? Thoughts? Thanks.
Seared
Fred,
The alternator is held in the fan housing with four bolts. I would remove the belts, remove the fan housing, and check these four fasteners. The other thing to check is the position of the fan housing relative to the engine case. Only do this with the belt tension removed.
Andreas
Andreas
Gentlemen:
Thanks. The pulley and fan are cocked within the housing which led me to think of reseating the alternator. Trying to remember how it was seated from my old days when I tore down a couple of my previous engines. Thanks for jogging the memory.
With the A/C belt off , it appears that the fan is not quite as close to the housing as it was. Thanks again.
Fred
Fred
