993 Forum 1995-1998
Alignment question...
Old Apr 30, 2009 | 10:41 AM
EvEr34's Avatar
EvEr34
Default Alignment question...
i've tried searching but....
Just finished getting the bilstein/M030 setup installed. I have an appt. for alignment this afternoon and was wondering what the ideal alignment specs would be for a weekend driver that is not to agressive?
Old Apr 30, 2009 | 11:40 AM
Stealth 993's Avatar
Stealth 993
RS specs.
Old Apr 30, 2009 | 12:07 PM
fast_freddy's Avatar
fast_freddy
Sadly your alignment shop will do as they please and give you standard spec alignment unless you pre-emptively tell them if they do it is coming back and they will do the work again at their expense. I have encountered this a couple of times unfortunately. Standard spec 911 alignment on a lowered car will understeer in a straight line, for real. RS spec while it willl tramline a little is a very reasonable compromise between handling, "stability" and tire wear.
