Amp install, has anyone managed to rid the whine by ....
A shield should always only be grounded on one end only. There's nothing wrong with a shielded signal cable if it's done correctly. I prefer shielded cable on low voltage signals to remove the induced noise.
I always decide which end I want grounded then fold back the other end of the shield and tape it down.
Don't confuse the power ground with the shield ground. The amp and the reciever both require their power to be grounded, but the shielded signal cable between them is what requires only one end to be grounded.
So grounding the signal shield at one end prevents this ground current from running right next to the signal wire and forces it to run on the power ground.
fantastic thread,
So to sum up,
1- remove negative (-) from radio
2- or take a negative (-) from radio to negative (-) of amp and use of unshielded audio cables if possible
3- or ground the radio out RCA that goes to the amp, to the radio ground
did I get it right....
So to sum up,
