ID front drop links
I need some help identifying these front drop links. The PO had PSS9's installed with a TRG front sway bar (according to the receipt). There was no listing on the receipt for front drop links, only rears. The part # on the top boot is 020 000 011 012 (not sure if it is a Porsche #). It is about 9.5 inches long. Can I get just the boots at either end or does the whole link need to be replaced? It does not feel like it is loose or worn. Any suggestions on a source for the parts? TIA
John
John
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Standard C2 drop links -- it amazes me that these are ratained with upping the bar spring rates. The C4 links are cast, while heavy, they are quite a bit stiffer.
Thanks for the help Chris. When an upgrade to this type suspension is made, do most people go with the C4/Turbo drop links? What other options are there? I don't use this on the track but some day I may attend a DE.
