big reds
I wonder if someone could advise,ive got big reds on my 993 c2 but am reasonably sure with std discs,what is involved fitting turbo discs as mine need replacing?,will stick with std if too much involved thanks for your help,
G
G
The difference between standard 993 fronts and Big Reds is ~10mm height.
the difference in rotors is 18mm, 304x32 std, 322x32 RS/TT
If you do have Big Reds then the 993tt rotors just bolt on to replace the std rotors.
You will also need to do the back, here the differences are greater. the std rotors are 299x24, RS/TT are 322x28. The RS/TT calipers are the same length and height as the std 993 front, just a tad narrower and use the same pads as std 993 fronts. There are 2 versions of these big rear calipers 993tt uses 28/28, 993RS uses 30/36. If you have the suspension, tires and lsd to use the RS they do allow greater utilization of the rear brakes, that's a good thing on a tracked car.
Gary, if you have the standard discs, as Bill V, says you will more than likely have regular calipers,,,unless you are going to track the car hard, regular brakes work well enough....unfortunately with the weakness of the £ and Porsches drive to get cash in to buy VW, parts prices have gone up,,RS/turbo brake discss in the UK are nearly twice the price they were a year ago, worth bearing that in mind before we even mention calipers......ouch!
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
![](http://i359.photobucket.com/albums/oo40/gary11_photos/AugSept08Gdwd035.jpg)
http://s359.photobucket.com/albums/o...t08Gdwd035.jpg
cheers G
Any recommendations on which proportioning valve to use on a C2 with TT calipers?
https://rennlist.com/forums/964-foru...ng-valves.html
Can I just remove the p/v and connect the line directly to the hydraulic unit? And wouldn't this pose a danger of excessive oversteer under braking?
