Amp under the passenger seat - Measurement and some options
Yes do the speakers......there are many threads on what fits. I just completed my focal VRS polyglas component speakers in doors. I actually removed all the "focal" emblems on the grills and it looks very close to stock. I'll post some pics later. I'll probly install the new JVC AVX-77 this weekend. Havent decided on an amp as of yet.
focal vrs components
new head unit (JVC AVX 77) full touch screen
I installed dynamat in the doors when the panels were out...... The sound is amazing!
Why didn't you keep the stock tweeter housing? It looks like the aft crease from the housing is still in the door.
Do you like the headunit? I checked it out on Crutchfield and it looks cool, but it seems like there is something that prevents DVDs from playing when the car is moving. Does the headunit have enough power to drive the speakers or will you have to install an amp?
I did considered putting the tweeter in the pod but it just didnt fit quite right. Stuck out a 1/4" . I could have angled it in there (did a test fit) but the sound was blocked by the pod. Im still happy with the install. Yes there is a little crease by the pod....Ive been trying to figure a way to get that out.
As for the JVC AVX77, I am really enjoying it. The DVD player while the parking brake is on....... its easily bypassed. As for looks, very subtle and you can change the background image color and text color. Theres infinite possibilities. I have it set with a black / plain background with white text.
These Focals look very nice. What size are they?
I would not worry about the crease around the tweeters.
Dremel would be the only way to make them fit in these damn stock pods, but your setup looks great as is.
I like the head unit too. Nice choice.
I did dremel the inside of the tweeter pod but was still not happy with how the focal tweets sat. I think they are the newer, bigger 1.1 ti tweets or something. The ones I have seen at car toys were smaller.
Anyways, the focal components are the 165VRS (6.5" slim fit woofer 2.2" depth). Yeh, Im pretty happy with the headunit. The only con so far is that scrolling thru the ipod is slow.
Update: I started to install my MB Quart 3 component system. I first thought that I will not be able to fit the mid and woofer under the grill. The woofers are not a problem but there is not much room fur the mid because they have a fairly big magnet. It needed some thinking but I found a way to get it done. The only way to effectively use the small room was to mount the woofer and crossover on a bracket made from plywood which fits the mounting holes of the old Nokia speaker enclosure and mount the mids directly on the door pocket. This needed some patience and basic mechanical skills but it fits and looks completely stock. After I figured everything out, the second pocket took me 30 minutes this morning to mount the mid. With this solution you might think that the MB quart system is built for this.
I will post pictures later.
P.S.: I fixed the broken holes in the door handles too. The post a couple of days ago came at the right time...
Update: I am done with the installation of my MBQuart 3 component door system (handmade in Germany like our 993s) !!! Everything fitted well but the Tweeters took more time than expected. They are very small and fit the OEM housing but I did not want to glue them. MB Quart delivered an angled bracket but to mount it it into the OEM housing it needed some dremeling. Next problem was that I needed to take off (cut off) and drill the OEM mounting plate to install the MBQuart bracket over it. However, with some patience I got it in. I took my time and got it all done over a weekend with watching some Bundesliga soccer in between.
The sound is very, very good but I did not spend any time to fine tune and I have not listened to my favorite tunes, too.
e9stibi--
I was wondering, is it possible with your set up to mount the bass speaker to the hole in the panel rather than constructing an enclosure? Or is the speaker too deep? Or is there interference with the mid etc etc??
