964 Buckle Support for Recaro PP's? (pic)
Need some help here. I'm trying to use stock belts with Recaro Pole positions. I think I need 2 of the 964 Brackets (964.521.065.00)
Wondering if that is all I need?
Wrong...
Wrong...
![](http://forums.rennlist.com/upload/belts.jpg)
I'm trying to get the female buckle farther down. As they sit in the picture they don't fit snuggle across the hips and the shoulder belt is more of a neck belt. I'm no safety expert but I'm guessing how I have them now is not as safe as it could be.
Have a look here:
https://rennlist.com/forums/6109127-post22.html
Even using the "964.521.065.00", it seems to not make a real difference.
Edit:
As I looked further down the thread, I think this is what you're trying to achieve:
https://rennlist.com/forums/6390543-post47.html
It appears with the "964.521.065.00", it makes it possible to have the female buckle at the tunnel side harness hole.
Edit:
I would have guessed that you feed the female through the belt hole on that side. Not sure how that would work comfort-wise, but, it should hold you closer to how the factory seatbelts on factory seats does it.
Speaking of... How do people do it with GT3 seats?
Bob
Bob
However, that the new GT2 seats have the female buckle through the tunnel side harness hole:
http://www.6speedonline.com/forums/g...ort-seats.html
