Anyone Have This Dead Pedal?
I installed that dead pedal for the same reason - it matched my other pedals. Fits fine and took about 10 minutes to install. It doesn't fill the area like the Rennline dead pedal, but I don't have any complaints. I just used the supplied screws and drove them in with my Makita.
My issue with a similar pedal was that it would it the curved carpeted plastic panel that sits above the pedals. interestingly, at the time, it did not appear that a '96 coupe had as much problem with it as a '95 cab. Which was strange, as i thoughts they were identical in those areas. But did not investigate further - sold the pedal and bought another.
Not that I've noticed.
The screws go in the right hand side of the dead pedal which comes in 2 pieces. I thought I might have to grind down the screws if they came through the wheel well but they don't. The one I got was much cheaper then the Rennline and Ultimate Pedal versions and was the match to the AJ pedal set I already had. IIRC I was going to get it from AJ but found someone on eBay that had much cheaper shipping to Hawaii.
