Door Check Strap Repair
#33
I think it is a function of how often and with how much force the door is opened. I never open my door all the way to the stop much less with any force. I expect my check straps to last forever, or at least as long as I own the car.
#34
Yep, same here. Even with Porsche's poor design just be gentle and watch out for inadvertent wind gusts and your door strap should last as long as you do.
#35
I need this done as well. I got two estimates, both in San Rafael, CA: Barsotti's said they would only do it as described by the OP in this thread. I left convinced they would do it right. Cost would be $2500. The other very well respected shop said they would weld the pin arm to the A-pillar and "clean it up so you would not notice". Cost would be $500.
I was quite disappointed. I would only do the former approach, but the cost seems to be about double what I was hoping. After my windshield replacement fiasco, I'm gun-shy about trusting shops.
Anyone had the OP's method done by a Bay Area shop with good results?
#37
![](http://yellowdieselgolf.com/data/images/barney/Doors/****.jpg)
I don't want to start a new thread, but does anyone have any tips on how to get the pins back in? I've hammered the crap out of mine but they won't sit down.
#38
I would be inclined to tap it out and check pin fitment in the door check strap and also separately in the bracket from the door jamb, to determine which hole(s) are too small. I might consider drilling out the check strap slightly, but don't think I would drill the jamb bracket. The fit needs to be snug or you'll get clicking.
However if the pin is securely in place and doesn't interfere with the opening in the door where the checkstrap emerges, it should be ok to just leave it alone. If the pin hits the door sheet metal (ie doesn't fit inside the checkstrap opening) that won't do.
#39
It should set with a couple of light hammer taps, at least far enough to expose the detents for the clip to hold it in place. If not, the hole(s) must be too small.
#40
Thanks gents. I pulled the pins out and inspected them and the holes. I found nothing to indicate that they were asymmetrical or keyed. I gave the pin and the hole a quick sand with 400 grit. I took a scribe and cleaned up the splines and then I lubricated the hole and tried again.
I couldn't get them to sit flush, but they are in deep enough that the clip now engages.
Thanks again.
Thanks again.
#41
Thanks again.
Thanks again.
