Valve Job pricing assist
#31
Seared
Sorry, guys, was traveling in SoCal this week.
My 993 is still running great after Exotech did the top end. $3500 sounds about right for just the top if everything else is okay, I think Mark is a little less expensive because he doesn't have to send the heads out and so forth. You might need a little patience as Mark is big into racing and I'm sure lots of guys are getting their cars ready for spring. On the other hand, with the economy ...
#33
Quick update:
My tech did a rudimentary SAI flush (for free!!) and he said I was still clogged badly, and the huge cost of labor to properly clean out the passages would be better applied to an engine out/top end job when the time is right. I agreed, told him I would do the G-string flush myself (that sounds fairly burlesque, huh?) and he reset the CEL and I went on my merry way. This AM I went to my friendly neighborhood emissions station and, despite several readiness paradigms not set...PASSED!
SO I now have two glorious years of SAI Procrastination and deferment to look forward to!!
#36
I have just run into the SAI problem in MA (see thread Emissions failure in MA). I have read the article on pcarworkshop and that article mentioned the same idea. Since I am on the east coast, I am wondering how much you enlarge the SAI passages?
Thanks,
Jeff
#37
RL Technical Advisor
I do this on the milling machine and enlarge them about 2mm.
