PPI in W. Houston, TX?
I would use Protechnik in SW Houston but here are some others from the local PCA mag. http://www.lsrpca.com/advertisers.htm
Of course there is Mike Callas out in Sealy. Can't go wrong there either.
Ken
Ken
3h? Mike Callas is on the 'West Side' of Houston in Seally very close to I-10. If the car is in the western area of Houston, it will be 1h max if you avoid rush hours.
Could you say more on the car's location? That might spark additional input. Also, might try the Pelican 911 board. The dealer out here is West Houston Porsche but I shy away from dealers.
All:
I googled Mike Callas and it showed the 3.5 hr distance. Car is in Fulshear, which is pretty close to Pro Technik.
Car is a silver/black '96 Carrera 4 coupe with 54k on the odometer. Private seller.
Thanks,
Paul.
Thanks,
Paul.
http://www.mapquest.com/maps?1c=Seal...Fulshear&2s=TX
this is his site: http://rennsportporscheworks.com/
