Question....
So was doing some service on the 993, upper spark plugs, and removed the blower from the left side of the engine. After getting the plugs changed, I noticed that there are 4 connectors and another part that goes on the piece that you remove from the blower.
My question is - is it possible that there are connectors that aren't plugged into anything? I don't recall unplugging 5 connectors. Suggestions/Comments/Help?
~Andy
~Andy
I'm assuming it did, I've only had the car since last May. I could call the dealer to verify. If two plugs are for the VRAM actuators, what about the third?
Andy, the 2 circled conn. in the pic below have a home. One goes to a plug near the resistor, the other goes to it's mate in the metal bracket with the 2 10mm screws.
You mentioned 5 conn., I see 4 in the pic.
Maybe the 5th you refer to is the resistor that sits in the blower tube?
Hope that makes sense... I probably have a pic if it doesn't.
