Starter problem:
Starter problem:
My '95 coupe has refused to re-start a couple of times when the engine is hot, although it won't do this every time, which is what's really baffling me?!?!
Anyone got any suggestions as to what it might be? Thanks in advance. Viv.
Sounds like the starter could be your trouble alright.
Normally the problem is with the starter solenoid being too heat battered and gunked up over the years to move. When the car is hot , I think the theory is that it takes even more electrical juice to drive the solenoid so that's when you see it at its worst.
As the previous poster said , under these circumstances you normally get a 'clunk' or a 'click' when you turn the key .. And nothing else!
Mine was replaced last year . My mech reckoned then that many of our cars would suffer starter failure as the motor is sitting right in the path of all that hot air as it exits the cylinders having been pushed through by the fan.
They're great cars but they're also just getting to that stage I'm afraid...
OT , but what's the story with your 'Irish guitar' name .. I like that one!!
If the starter turns, but produces a horiffic ratcheting noise when attempting a hot start, the bendix drive is shot = starter replacement: the noise is the clutch pawls inside the bendix destroying thenselves as the nose gear rattles in the ring gear. Those were the symptoms of my starter. You can live with for adequate time to arrange replacement, provided the car is allowed to cool down a bit.
A failing solenoid will often, but not always, 'click' as mentioned - but fail to turn itself, never mind the engine.
No noise/click/etc., = all sorts of electrical issues, so please pass on some more data ...
Thanks for the replies:
Mike J, I haven't replaced DME relay, will look into that.
NC TRACKRAT, it's neither clicking nor silence, more like a failing lurching sound - like a dying battery. However, I had the battery checked last night and it's still good.
Shamrock, Thanks for the info. I wasn't feeling too inspired when I came up with my Rennlist name that particular day. Fact is, I'm Irish and I just happen to play guitar. I could've done better I know. Joyce and Yeats et all would be most disappointed in my letting the team down!
Garth S, I've been trying to replicate, but as mentioned, the car doesn't always exhibit the symptoms - which is why it's such a mystery. I'll post more as I find out.
Regards.
Regards.
I had the same thing happen to me once. The weather was around 95 outside ,which is pretty hot for where I live. My car got hotter than I ve ever seen before. I turned the car off to go into a store for a few minutes and when I came back and tried starting it, it sounded horrible. Not just a click or silence. I turned it over and It just did not sound right at all. I then gave it a few minutes to cool down more and tried her again. Luckily It started up and off I went. This has only happened once . Now, I dont let it get that hot. I think it was a combnation of hot weather and ****ty oil that made it get so damn hot. I'm still puzzled about the whole thing but have taken measures to prevent over heating (ie: Oil fan overide switch installed) And of course I get my oil change at the appropriate intervals. (Brad Penn Racing oil only) Not sure if this helps at all but at least know that your not alone.
As mentioned above, let's hope it's the DME relay. Part number is 993-615-227-00. Should be around $30 shipped. If it's not this then you keep it as a spare.
I suggested the DME because its common, and from the wording of the first post I could not tell if the car cranks. "refuses to re-start" is not enough information. Later, the information that the starter turns over but does not sound right came to light, which does not sound like the DME.
Cheers,
Mike
I had the exact same problem. Cold starts, it would fire right up. Hot starts, bubkus. I replaced the starter, problem solved. It didn't cost too much if memory serves, $250~, plus two hours labor.
I have the same problem. The DME did not fix this. And the startup is only a problem after the car has been running a while, I shut the engine off, and then come back like 5min later. Any suggestions where to buy the starter from? Maybe I will do a short shifter or something while the car is at the mechanic?
