993 Forum 1995-1998
Pulley Update: Why Bother?
Old 01-16-2009, 11:25 PM
Cactus
Noodle Jr.
Cactus's Avatar
Originally Posted by TheOtherEric
I just ordered the new pulley. Darn thing was $60.
Sunset? Is that all you need for the upgrade? Besides the belt of course....The TSB I printed out has shims as well.
Old 01-16-2009, 11:30 PM
AOW162435
Seared
AOW162435's Avatar
Would probably make sense to get whatever shims come with it - unless you can ID the ones you have. I seem to remember that they have small holes in them for this purpose.
Andreas
Old 01-16-2009, 11:43 PM
timothymoffat
timothymoffat's Avatar
Originally Posted by Mike J
Go onto www.pcarworkshop.com and look for the TSB.
Cheers
Mike
Interesting reading there Mike. One TSB even says that 993s "should not have ride height lowered."
Old 01-17-2009, 12:10 AM
black ice
black ice's Avatar
Found another old thread that said the shims for the updated pulley halves are different. Not sure why. have to research tomorrow...
dave
Old 01-17-2009, 12:20 AM
TheOtherEric
TheOtherEric's Avatar
Hmm. Looks like the TSB calls for both 0.5 and 0.7mm shims, as needed. Looks like our 1995 cars come with just the 0.5 shims (same part #), so perhaps ordering a couple 0.7mm shims wouldn't hurt.
Old 01-17-2009, 04:00 PM
black ice
black ice's Avatar
Well lesson learned, the NAPA belts suck. Don't think they're actually bad belts, just all seem to be sized incorrectly. I put a Porsche belt back on the alt pulley and it is now plenty tight, where I could not get it tight enough before.
Another difference with the NAPA belts is that I think they are a different pitch, and they are also 10mm wide versus 9mm for the factory belts.
Also a note about those crappy hex-head bolts in the back pulley. I had two pretty rounded off - they will come out with a very tight pair of vise grips on them. There is enough clearance back there for deeper hex head bolts.
dave
Quick Reply: Pulley Update: Why Bother?
