Power bleeder
Most here find the Motive Black Label bleeder to work great. The cap is a direct fit for most European cars. It's worked out great for me.
Here's their site: Motive Products
Power Bleeder
I've used it on Brembos with no issues.
The benefit to the Motive vs the other suction types is that it's impossible to suck air into the system. I was bleeding the slave cylinder, dropped the wrench, and introduced a ton of air into the system. I got the Motive after that episode.
Just a reminder while I'm reading this, since I did this Saturday (sounds like I might be the only dumbass to do this). You have to pinch off the overflow hose on the back of the master cylinder when using a power bleeder or the fluid can get pumped out. It comes out of a hose hidden at the very bottom of the back of the left front wheelwell.
dave
dave
From: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
Almost everybody loves the Motive bleeder and if I did not have a compessor, I would use one as well.
The Eeziebleed was designed to use the pressure from one of the cars tires but I simply installed a QD and connect it to my compressor with the pressure dialed down ot 15 psi. I have used it about 30 times now as we have 3 German cars that all get the brake fluid changed every 2 years.
I bought it at IPD but they do not carry it any more. It is available here:
http://www.autoexpertproducts.com/eezibleed.htm
A good buddy of mine with a Volvo first turned me on to it. Works great! I borrowed it from him and promptly bought my own from IPD.
Oh BTW, the inspiration for the Eeziebleed came from Robin Suns' p-car.com site where he put his own together..
Cheers!
Cheers!
Last edited by Bruce SEA 993; 01-13-2009 at 10:13 PM. Reason: Added Robins' reference...
Wow...thanks guys for all of the input. I went with the Motive Black. I have 3 German cars and it will come in handy, Thanks for the tip in the overflow hose...
Just waiting for my oil filters and tranny mount...still up on jack stands..
It is easy to upgrade the 95MY reservoir to the later style - try a search - I thought it used to be detailed on p-car.com/diy but I don't see it anymore. IIRC you need a 96-style reservoir cap and a clamp to clamp off the overflow hose. Very easy DIY.
HTH
dave
dave
