DIY OBD-1 Varioram Conversion Step by Step (More or less)
#48
Thanks for the write up. it is very helpful. I have ECU-- Early 95s (no drive block) – Porsche # 993.618.123.02 You state this will not work and needs to be updated. Do I need to keep it late 95, since I do not have drive block, or will an 97-98 work. I think I have read that 96 ECU's can not be chipped. Do I also need to change the ECU harness, and any thought on the cheapest way to do this?
Cheers,
Emerald
Cheers,
Emerald
#49
Cheers,
Emerald
Cheers,
Emerald
Beginning with the later 95 cars and up through 98 buyers could specify drive block.
If I were you, I'd stick with OBD-1. Besides the fact that OBD-II is a PITA, it will be much more work to convert your OBD-1 car. I'd source a later 95 ECU w/o Drive Block which is Porsche # 993.618.123.03 / Bosch # 0.261.203.674. You can chip this ECU as I describe above to operate the VRAM. As an alternative, you can troll Euro ebay (probably German, British or Italian) to source a 993.618.123.11. This is the Euro OBD-1 ECU w/o drive block. It will be plug and play for the VRAM - no chipping required.
If you have the recall wiring harness, you will have all the VRAM connectors in place.
Hope this helps. Please let me know if you have any more questions
Cheers,
Joe
#50
Hi Joe,
I have an 993.618.123.02 ECU. I know you suggested finding a 993.618.123.03 for my 95, but I have found a 993.618.124.03, which I believe has drive block.
Can I use this and have drive block removed, or is it too much of a PITA?
Thanks for the help.
Cheers,
Emerald
Cheers,
Emerald
#51
Hi Joe,
Cheers,
Emerald
Cheers,
Emerald
I don't have experience with adapting a drive block ecu to a non-drive block car. However, I'd speculate that it's not worth the effort - especially since you don't already own it. I imagine you'd need to adapt drive block to your car (surely a PITA), or somehow modify the ecu to remove the drive block specification. Either way, I wouldn't bother messing around.
Cheers,
Joe
#54
You can use a drive bloc ecu in a non drive bloc car as long as the chip is replaced w/ a non drive bloc chip. You will need to replace the chip anyway when going from non v-ram to vram.
#55
Hey Bill,
so if I have a non-block 95, I can take one with drive-block and just replace the chip? This almost sounds too good to be true, but I thought I had read in past posts of guys getting rid if drive block due to frustrations.
I was going to have Steve chip my ECU when I was finished building the engine, so I assume this could be taken care of then.
Thanks for the great info.
Cheers,
Emerald
Cheers,
Emerald
#58
Hi JM 993
I just saw your article about fitting a Varioram inlet manifold to a non-Varioram 993. You article inspired me to start looking for a Varioram inlet manifold (If there is one for sale among Rennlist members, let me know). I do have one question regarding this retro-fit:
Is it possible to fit a Varioram inlet manifold to a 1994 993? I am asking since the pipes/lines for the airconditioning are diffrent on the early cars, or can I just fit the pipes/lines under the Varioram inlet manifold?
I do now I have to change the ECU and the heater ducting, but thats only minor (I think, haha)
My engine does have the upgraded wire loom so no problems there.
I would like to thank you in advance for answering my question,
Regards,
Rutger
Regards,
Rutger
#59
Hi JM 993
Regards,
Rutger
Regards,
Rutger
Yes, you can update your 94 to Vram.
If you want to retain your A/C you have 2 choices. First, you can do what I did and purchase the later style A/C lines from the compressor. You will need to fabricate a simple bracket to secure the lines to the fan housing (not hard). Incidentally, for those with late 95 cars, the fan housing already has a boss for the A/C line bracket but the earlier 95 (and 94 cars) do not. Second, you can reroute your early style A/C lines across the engine bay and then along side the driver's side frame rail - essentially following the same path as the later style lines. This is possible because the early style lines are predominently rubber (i.e. flexible).
Hope this helps. Please feel free to ask questions along the way.
Cheers,
Joe
