Ahem. I have talked to them several times. They did offer to swap mine for a custom set if I wanted but I went with what I had. They are an older set which they said the valving is more track biased then street. I think the one's now have a more street biased.
You just need a 2.5in spring, if you know the length, I can get you any spring you want, they are cheap.
If it's bouncy on soft, most of that would be due to the spring rate, it's over powering the dampening. With a softer spring, you can run the softer setting & get a better ride.
Bill,
So to dial out some of the understeer can't you just get the closest JIC spring rates to OE Springs. I't won't be exact but close.
I'm sure this has been beat to death, but where to do get RS Shocks and Springs from. Are these good 'ol bilstein shocks.
To dial out some understeer, you just increase the rear dampening rate a bit, or use a stiffer spring it the rear.
RS shocks are revalved Bilsteins, there are a few places that sell them, I just saw a set of fronts on eBay. RS stuff is going to be stiff, don't forget it was tuned for a car that is a 400lbs lighter.
