993 Forum 1995-1998
Engine/Tranny Removal Help
Old Oct 17, 2008 | 08:58 PM
North Coast Cab's Avatar
North Coast Cab
Default Engine/Tranny Removal Help
I am down to the last steps of the engine/tranny removal and I am stuck.
I removed the tranny crossmember support, but it appears as though there are two support bars that go from the point where the crossmember and tranny meet to inside the tunnel a ways. I don'tsee any reference to this in the engine drop threads.
Do they need to come out? Sorry, first 993 drop so I am a rookie.
TIA, John
Old Oct 17, 2008 | 09:56 PM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
yes sir, take a 17mm (IIRC) boxed end wrench and reach up there in the tunnel removing the two bolts. They arent very long, and easier to get out that what it appears.
Old Oct 17, 2008 | 11:47 PM
herman maire's Avatar
herman maire
Yup, needs to come out.
Are you taking a bunch of pics?
Old Oct 18, 2008 | 09:12 AM
North Coast Cab
Thanks, it seems to have swung down and now I just need to remove those two bolts.
I have not taken any pictures, but I wil once it's out.
Old Oct 18, 2008 | 09:29 AM
baron95993's Avatar
baron95993
cant wait to see the pics. With 218000 it will be soon for me I think.
Baron
Old Oct 18, 2008 | 12:17 PM
North Coast Cab
Ok, she's out. Thnak for the help. Looked obvious, but I didn't see any references to that in the drop threads.
Next, I can't seem to get the transmission seperated form the engine. On the 915 I am able to press the fork and wiggle it off, but in this case I can;t seem to get it. It is pule dout about 1/4" but I can;t get the fork to dissengage. Am I missing somehting?
Thanks again and I'm sure this will not be my last post on this project.
Full rebuild
Tranny freshen and LSD rebuild on the way.
John
Old Oct 18, 2008 | 01:07 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
Gotta remove the t/o fork cross shaft before you can split the lump/trans. There is a 10mm headed bolt near the diff cover on the trans, local to the bellhousing. remove the retainings strap, then the black plastic dust cover (round) this exposes the threaded end of the cross shaft. I made a T-handled extractor, but you can use a 6mm bolt to screw into the shaft, which allows you to pull it out.
Old Oct 18, 2008 | 01:10 PM
cgfen's Avatar
cgfen
nice avatar, Chris
is that from Fuji F1?
Old Oct 18, 2008 | 02:04 PM
North Coast Cab
I got it. I suppose I should have researched more before I dove in....
Tranny is sepeated and engine is ready for the stand.
