Helium in tires??unsprung weight savings??
#31
I thought that the lunar rover had mesh tires. 'Cause, like, there totlly wasn't any atmosphere to push back and make tire PSI work.
But I still weigh 30 pounds on the moon, dude.
#32
Be careful with using helium in your tires. You will basically have four Goodyear balloons at each corner and it will upset the cars handling.
make sure your pressures are dead on or you could have one side of the car, or the front, or the rear, lifting with no warning (even when parked).
#35
I suppose you can achieve the Hindenberg affect 4 times with hydrogen filled tires, as you can always tell who buys their Nitrogen filled tires at Costco with their green plastic valve covers. Do you guys ever wonder what NASA used to fill the tires of the lunar rover overtime parked on the moon?
#37
#38
Well i just repeated what someone had mentioned to me and i found it quite unusual so i decided to ask the board what they think...whether its a silly question or not....i always respected and appreciated the advice given here because im no guru i admit...and i have heard and read some silly questions over the years... if some of you think its a silly or stupid question then too bad...grow up..some of us are still learning and want to learn more because we love our pcars and are always looking for ways to improve our pcars and ourselves...
