993 Forum 1995-1998
alternator noise still
Old 09-18-2008 | 06:39 PM
johnnypiedras's Avatar
johnnypiedras
herd i with old and new alternator
Old 09-18-2008 | 06:40 PM
johnnypiedras
is armature somthing replaced when u get a new alternator ?
Old 09-18-2008 | 06:48 PM
Allen's Avatar
Allen
A few years back, I had my belts replaced...including the alternator belt. When the shop put the new belt on the alternator, they didn't adjust it correctly. Apparently the adjustment procedure for that belt takes a special tool or is not straight forward, or something. The result of the misadjustment was that my alternator bearing was making a "whining" noise when I accelerated. Not really that loud, but consistent.
When you can hear the engine sounds as good as you can on these cars, the slightest variation in the sound is easily noticed. Such was the case with the bearing noise. It wasn't that loud, but it was easily detectable. I'll bet you have an altenator bearing going bad.
Old 09-18-2008 | 06:58 PM
johnnypiedras
dont these bearings get replace when changing out the alternator?
Old 09-18-2008 | 08:25 PM
Laura's Avatar
Laura
Check the fan bearing hub located on the alternator shaft. These commonly are damaged/worn and may cause noise and/or cause the belts to fail. 964.106.051.30 When you are replacing the alternator at 100K, this bearing also has 100K wear.
Old 09-18-2008 | 08:52 PM
johnnypiedras
does a new bearing get replaced automatically with a new alternator
Old 09-18-2008 | 08:54 PM
MarkD's Avatar
MarkD
maybe
should be
no, not a part of the alternator (fan bearing).
Old 09-18-2008 | 10:35 PM
johnnypiedras
fan bearing was replaced when i changed to rs pulley
