Clutch pedal hanging up
My cluth pedal does not return all the way when released. Feels loke a mechanical, not hydraulic problem. Any fixes?
Lifetime Member
Lifetime Member
The standard procedure seems to be:
1. bleed the clutch
2. replace the clutch slave cylinder
3. replace the kinematic lever
Those are in order of difficulty, so people seem to just go down the list until they fix it. I ended up doing all three.
1. bleed the clutch
I had this happen on track. Its the bushing. Only happened when very hot and it would stick. Would go away when cooled down. We will change it out to a brass unit when we pull the motor this winter to rebuild.
FWIW
FWIW
Based on what you described mine sticks @1inch from full return. Porsche mechanic drove it and after pumping up pedal it engages correctly. He suggest replacing the clutch master cylinder. Car has 100K miles on it. I can also manually use my left foot to "pull" clutch pedal back. It will softly "click" into place using that method but, will go back to same "stuck" area.
Replacing the clutch master cylinder is NOT the typical solution to this very common problem. And since you have a 1995, you have the old kinematic arm before its redesigns. Sorry, but your mechanic is very likely wrong on this. He may know better (he should!) and is perhaps just inflating the bill.
Lifetime Member
Lifetime Member
+100 Couldn't said it better.
Eric and others,
Appreciate your input. Car is scheduled for some other general maint at well known air cooled Porsche specialist (Akers in Seattle). They are familiar with this known issue and will be happy to give it a look. Thanks for saving me some $$ and frustration. I will follow up w/you guys after cars appointment next week.
Cheers.
Cheers.
