993 Forum 1995-1998
Sneek Peek at the Blue Beast Coming together
Old 09-30-2008, 07:58 PM
  #61
Austin
Austin's Avatar
Originally Posted by viperbob
Are you a straight man Rick? You'll probably see that post in a matter of minutes..
ViperBob!
Good to see you here, has anyone yet said this is a kick *** project?!
I heard about that engine work going in there too, what's the deal? I hope AC993C2S puts some details about that up when it's ready!
Old 09-30-2008, 10:10 PM
  #62
jaholmes
jaholmes's Avatar
Originally Posted by Bill Verburg
looks like RS rears?
any better of the tilting blocks?
Can anyone explain the GT2 tilting blocks. Is this just for a complete GT2 suspension or is it the ultimate bad *** suspension.
Old 10-01-2008, 02:04 PM
  #63
viperbob
Former Vendor
viperbob's Avatar
The GT2 tilting blocks gives the rear suspension cage a downward tilt in the front. As the cars accelerate, the rear tends to squat. As it does, the factory tilt of the suspension cage will tilt up in front and change the geometry of the rear uprights and all those pretty heim jointed arms. With the GT2 setup, as the rear squats a little it actually brings the entire rear suspension into a neutral position. Hope that makes some kind of sense..
Old 10-01-2008, 02:21 PM
  #64
Joe S.
Joe S.'s Avatar
Awesome!
Old 10-01-2008, 10:30 PM
  #65
FLA997
FLA997's Avatar
One More for now...the car is being painted and off to final assembly soon.
Old 10-02-2008, 12:27 AM
  #66
David Ray
David Ray's Avatar
You inspired us for the RS look, now this! Fantastico! Beautiful theme.
Old 10-03-2008, 06:40 PM
  #67
V
V's Avatar
Wow can't wait to see the final result..
Regarding the heat exchangers, why did you remove them? Was it just to be able to coat the headers (inside and outside)? What are the potential pros and cons? Just curious..
Old 10-04-2008, 12:46 AM
  #68
FLA997
FLA997's Avatar
Viggo-
The heat exchangers were removed because the heating system (and entire AC system) have been completely removed from the car, so there was just no use for them...and they were ugly anyway. ;-) The only way any air (hot or cold) is getting into the car is thru the door windows....or should I say the door window openings - the window glass and all the crap inside the doors; glass, motors, power window switches, etc is gone as well.
Old 10-04-2008, 07:45 AM
  #69
CWay27
CWay27's Avatar
screw the slippery slope. Buddy, you went off the cliff of this one!! Nothing has been spared and beside the tub, this car will feel completely different from last time you drove it. Be careful when you take it out.
Old 10-04-2008, 11:35 AM
  #70
V
V's Avatar
Originally Posted by AC993C2S
Viggo-
Ok, I got it . So cutting the heat exchangers off is not for us with AC etc I guess..? I still remember when you had your pristine C2S GQ sitting in your garage.. Rob, you are the rennlist spirit personified . Keep us posted, many of us dream of doing something like this, sometime.... Can't wait to see the beast once it's finished!
Old 10-04-2008, 09:57 PM
  #71
FLA997
FLA997's Avatar
Absolutely!
Old 10-04-2008, 09:58 PM
  #72
FLA997
FLA997's Avatar
Correct...bad idea for a street car...unless you just dont ever use your heat. ;-)
Old 10-25-2008, 02:45 PM
  #73
FLA997
FLA997's Avatar
Getting closer - a few pics from the body shop:
Old 10-25-2008, 03:01 PM
  #74
V
V's Avatar
WOW droooool....
Rob, what changes have you done to the engine? I heard you have the RS gearbox as well..
Old 10-25-2008, 03:08 PM
  #75
FLA997
FLA997's Avatar
Engine: 3.8 RSR P/C, RSR Cams, Big Valves, Solid Lifters, Carillo Rods, Titanium Valve Springs, ARP all around, etc, etc, etc & Protomtive Tuning...and yes, the car has a G50/31 RS gearbox.
Quick Reply: Sneek Peek at the Blue Beast Coming together
