Correct Tire Pressure And Size
993 front tires are Bridgestone Potenza S-02 size is 205/50ZR17. Rear tires are Bridgestone Potenza RE050A size is 255/40R17
What are the correct cold tire pressures?
Are these the correct size tires for the cup wheels?
Thanks!
Thanks!
If you do a search, you will find an awful lot of discussion re. tire pressures.
FYI, the 'recommended' pressures are too high
. Most people settle around 36-38 rear, 32-36 front. Depends how hard you drive the car, alignment, tire type and wear pattern, and preference.
