3rd Brake Light -> LEDs
You know, you have a very good point Justin ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
My Wife is starting to wonder why I'm spending so much time in the garage these days. Might as well have a valid excuse to do so. I go out there to just look at it several times a day. It's hard to believe it's mine, and I never get tired of looking at it
I replaced mine a few years ago and haven't had an issue since. Regardless, the schematics would be on the workshop manual. Maybe someone here can scan the page. Otherwise, just follow the wire down to were it gets power and put the resistor there. You might even be able to fit it right in the assembly on the roof.
I'll see if it will work for me. If I do replace the bulbs with LEDs, it should fit just fine, the LEDs shouldn't be any larger than the bulbs.
Noodle Jr.
I just assumed they were LED's since they are so small. I like the LED replacement idea though. Subscribed......
I just did my 3rd brake light in all LED s. I did it because of all the bulbs that need to be replaced. Since I had it out I just did LED's. the look is great at night.
Mike
Mike
Bingo
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Could you please provide some details:
- what LEDs did you use? white? super brights?
- where did you get them?
- did you just solder in the LEDs where the incandescent bulbs were? same height?
- did you have to add a current limiting resistor?
Thanks, you made my day!
Gary
Hi Mike,
Bingo
, I was hoping someone would have at least thought about this by now.
Thanks, you made my day!![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Gary
Bingo
Gary
I used the super bright red led's. The whites wash out the red lens believe it or not.
A friend of mike is LED crazy he has a ton of these. Many websites offer them for sale like www.superbrightled.com
I didn't even use the existing strip though I guess you could. The bulbs I used were a touch smaller so I took a small piece of clear tubing the length of the bulb socket and the LED's slid right in.
I soldered them in series of six using 1 resistor per grouping Some said and say each bulb needed a resistor but I didn't see it being needed. I think there are 18-24 bulbs IIRC.
Hope this helps.
Mike
Mike, thanks for the detailed information - any photos available of the final product?
Someone should consider mass producing the LED light strip for the 993 ...![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Hope this helps.
Mike
Hope this helps.
Mike
Super Moderator
Needs More Cowbell
Needs More Cowbell
Since the original poster is a PCB designer, you are halfway there.
The only remaining question is how you want to configure the LED's....series, parallel or a combination.....or how you want to power them.......vehicle 12V bus with dropping resistor or active IC power supply (current source).
Childsplay.
Childsplay.
Do a search on LED brake light and you'll find some additional info on series/parallel and resistors.
https://rennlist.com/forums/showthre...ed+light+brake
Hey Mike. How do we add a strip of LED to the Turbo wing on a Cab? As I no longer have the 3rd brake light, I am wondering if this is a possibility? Any thoughts?
Hey 95FL993CAB, I was thinking, have you contacted a stereo installer yet? Mine is one of the top 10 installers in the country, and he can do ANYTHING with plastic. It would be very easy to mold the original brake light lens into the rear wing and make it look OEM. He turned the center dash panel of my New Beetle from a single-DIN to a double-DIN to fit a 7" nav screen, and it looks so good that it looks like it was from the factory. A light should be pretty easy, but you'd have to repaint the wing.
You have a good point. I am trying, if possible, to not get in to paint, but I am not sure I would be able to avoid that. There must be a solution, but it is eluding me right now
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
OTOH sometimes the bulbs aren't really burned out. On my '96 (64K miles)I thought I had several bad bulbs but when I took the light apart, I found that where I thought I had bad bulbs, I really had bad solder joints (or even lack of solder) I just Re-soldered the bad ones and went over the rest of 'em and all are working well at this point.
Glenn
You can quickly pull off the 3rd brake light housing, unbolt the lights, and see if you're getting 12 volts.
Hope this helps.
Mike
Hope this helps.
Mike
Hey Mike,
Thanks for the info. I think I may move forward with this. I would design a drop in PCB with LEDs to make it easy to install. Once I design it, I'll have to see if there is enough demand to justify the cost.
Thanks again,
Gary
