PPI report...need advice please
had PPI done today on the 1995 993 w/99K miles in SF
here is compression test results...my concern is the #4 cylinder
cylinder
#1 200
#2. 203
#3 190
#4 160 ***
#5. 195
#6. 200
how much of a issue is a 20% difference in compression?...cylinder was tested 2x
cylinder
#1 200
#2. 203
#3 190
#4 160 ***
#5. 195
#6. 200
That's a whole lot of difference - have always heard 5-10% variance to be OK.
I'd want a leakdown test before I'd buy.
I wouldn't buy the car as-is. Something's not right in that cylinder.
You've already paid for a PPI so you might as well try getting more information and negotiating.
Personally I'd get another PPI including a leakdown but ask the seller to pay. No one is going to buy that car without a PPI and the next guy will see this same result.
As part of the PPI, have them include an estimate for the repair. It could be $$$ in this case.
At least then you'll have a much better idea on a reasonable price for the car.
Not sure who did your PPI, but I'd recommend RMG (realmeangarage.com) or S-Car-Go (http://scargoracing.com/)
That's a 20% difference, not 40%.
In the old days we'd squirt some oil into that cylinder, and run the test again. If the compression goes up, the problem is rings. If it doesn't, the problem is valves.
i discussed compression results with the owner of the car...both he and a friend of mine (who is a porsche mechanic) suggested driving the car hard for the afternoon tomorrow and owner also will add techron to fuel to hopefully loosen any carbon deposits if this is in fact the problem
shop will retest cylinder#4 in the afternoon when car is brought back to shop
hopefully this solves the problem
I can answer that one -- because it might not need a top end rebuild. The leakdown number might simply be a very common occurrence, such as carbon lodged under a valve because of the removal of the spark plugs. That's why you drive it and re-test. Elementary stuff.
The rest of the story...
The solution: a full bottle of Techron into half a tank (labeled for use w/ 14 gallons), supplemented with some 100 octane (76 station on Woodside Road in Redwood City has it on a pump) to get the crappy California gas up to an average of 93 octane, followed by 2 hours of GLORIOUS throttle stomping up and down the mountain roads on either side of Skyline (the ridge down the peninsula south of San Francisco). After this, it was definitely "breathing" more freely, and the idle was dramatically smoother. Back to the shop for a retest of the #4 cylinder and the adjacent #5 cylinder for comparison, and both tested at 195.
Nothing like a good Italian tuneup to help these beasts purr like they are supposed to.
(Note: this was immediately followed by an oil and filters change, so whatever crud the Techron flushed into the oil won't be hanging around.)
It's nice to have stories with happy endings!
-Knute
(Former owner of William's '95 993)
-Knute
william is extremely happy
and i must say, knute, who sold me the car couldn't have been more patient, helpful and willing to remedy the situation...it really makes a difference when a seller takes the time and energy to explain the car fully and answer as many questions as an excited buyer may have.
can't wait to pick the car up on 9/10...
if i can't bend over and down to get in the car because of my syurgery, at least the service techs can shoe horn me in!
wm
wm
