I'm running the same setup as Mark.... just incredible sounding when you dip your right foot into it .
Thx to Mark's suggestion, I have CC inserts coming this week. When I get a chance I will post some video with and without inserts.
Matt,
Definitely let the board know which CC insert you have (2 or 3 disc, flanged or not). I am thinking of the 3 disc CC since stuffing these things into a Supercup is hardly a real "muffler". I also don't want a 3 dics set up to sound and feel like a UPS truck.
Originally Posted by Carrera Mike
Where is your next race?
My next race is at NJMP, New Jersey's new race complex. Next will be Summit and then, hopefully, Carolina Motorsports Park.
Mark,
After talking with Ken (really helpful guy), I decided to go with the 2 disc 3.5" setup. I don't think the 3 disc product will fit, but I'll let you know - and will post some pics - this coming week.
...I decided to go with the 2 disc 3.5" setup. I don't think the 3 disc product will fit...
I also went with the 2 disc CC insert when I got tired of repacking the fiberglass baffles. IIRC one of the reasons I went with the 2 disc set-up was because the 3 disc wouldn't fit.
Thanks, David. Looks like 2 discs is the only way to go. Did you go with the flange or non-flange style? What were your reasons?
I went w/non-flanged as the flanged versions weren't available back then (IIRC). For my set they were a very tight fit and would take some effort to removed them if I wanted to run straight, catless, exhausts.
Thanks for the elaboration. How do they get secured into the supercups?
Glen - there are two holes 90 deg apart on the trailing surface of the Supercups that are used to mount turndowns. I suspect that I can use some hardware to tack the inserts in so they can be easily removed. I'll let you know this week .
I plan on using either a through-bolt or two smaller bolts to hold it in. Might have to cut and fab some right-angle pieces of aluminum if the trailing end of the CC's don't line up perfectly with the bolts.
