Air intake with fog light
Yes, I know they aren't Porsche or TechArt style. But this weekend I saw a Techart car and was not immpressed with the fitment of the "Originals". First the ones I got hold with the fog lights so it seams that they also have a better hold of the air duct and the fog light.
Richard
Richard
This is a fascinating setup. You're right that the duct is designed to hold onto the fog light better than Techart's. (I own Techarts). But still, the Techarts typically fit fine. Do your fog lights have the small running light in the corner like Techarts?
BTW, the fog lights are merely Jetta Mk II fog lights. Techart mods them by installing this light into them, plus glues on a couple nubs for mounting to the duct. Techart uses Hella (OEM) fogs, but I assume these are Chinese replacements. The Chinese fogs aren't quite as nice, but are fine.
I am not trying to say that the one that I have are the best. I got them here on German Ebay. And also got a second Pair from the seller and I got them for a good price much cheaper then the "originals". Because the I believe that the TechArt's are copy from Porsche that they have in the listed in the Tequipment catalog they had two version in the catalog. And of course do I have Hella light with the white side markers.
@TheOtherEric
Where you able to mount the black end caps on the fog lights with it installed into the car? I had a little fittment issue with them.
Richard
@TheOtherEric
Richard
@TheOtherEric
Richard
@TheOtherEric
Richard
No, I could not mount the black end caps on the fog lights either with a U.S. bumper or a Euro bumper cover. Again, these are made for VW so it just didn't fit a 993 perfectly. I made a cover using a bicycle tire inner tube and some glue.
Richard, Can you post a link to the Ebayer for these, Please?
They don't appear to be on German ebay. Search www.ebay.de for Porsche 993 Lufteinlässe and you see some others, but not these.
Yes, the fog lights are from a VW Golf. Mk III? I forget offhand, but I've posted the details in this forum. You might search on Golf and TheOtherEric and you'll find it. You can also get Chinese-made versions, and they're fine but not quite as nice since the glass is a bit thicker. Works for me though.
Techart made a couple little changes to the VW fog lights; they installed the driving lights and also glued on a little plastic piece that helps locate it against the duct.
Check out this article for some information about adding lights to the ducts...I did the DIY, I wanted somme real lighting.. :-)
http://www.pcarworkshop.com/index.ph...lla_Fog_Lights
Cheers,
Mike
Cheers,
Mike
