Drooping engine sound insulation
I have replaced mine without dropping the engine, but varioram out.
Would I pull it out without dismantling anything? NO
The original glue stuff doesn't hold on the metal and goes of with the pad, but if you pull and tear, pretty much could fall everywhere, and maybe
flame, generate bad smell, etccheck the picture you realise if you pull and tear, there are plastic caps (metalic studs) well behind that you could not remove...
hi everyone, the foam extends down until behind the horizontal cables in the picture. The foam at the corners of each side behind the intake, surround two well openings taking electric harness etc to the front.
