993 Forum 1995-1998
YAY!! Fixed my break squeal!
Old 07-21-2008, 09:08 PM
ste993
ste993's Avatar
Default YAY!! Fixed my break squeal!
I bought some foam wheel cleaner from the local auto supply store on Sunday and spent the day cleaning the car. I sprayed the stuff on the wheels and directed a load of it into the pads thinking and praying that it might cure my nasty truck sounding squeal. After letting it soak for about 60 secs I blasted the pads with water and saw a bucket load of crap come out.
So now to the test drive.... just 300 yards from the house the squeal was still there but seemed to be fading. Half a mile from the house it had gone!
I've done about 120 miles since then and have no squeal, not even a squeak!! If anyone is interested in the product I used let me know.
Old 07-21-2008, 09:22 PM
early_grayce
early_grayce's Avatar
Please share
Old 07-21-2008, 11:20 PM
ste993
ste993's Avatar
Originally Posted by early_grayce
Please share
Ok, I hope it will work for you too.
No affiliation, etc. etc:
http://www.eagleone.com/pages/produc...sp?itemid=1003
Old 07-21-2008, 11:51 PM
Denise993
Denise993's Avatar
If this works... I'll owe you a case of beer... the squeal is making me nuts!
Old 07-22-2008, 12:08 AM
ste993
ste993's Avatar
I hope it does work for you, I really do. I stumbled about this purely by chance and am just SOOO happy that it worked for me.
It's been bothering me so much for ages and I have been actively watching and talking to others on the list about this issue.
Good luck!
Old 07-22-2008, 10:33 AM
CarreraX
CarreraX's Avatar
Can you tell us what kind of pads and if you have the spiders or something else in there?
Old 07-23-2008, 09:21 PM
ste993
ste993's Avatar
^ Hmm, I can't be sure to be honest.... sorry. Still the same shoes the PO had put in which have about 30% left. All I can say is I've done over 250 miles since cleaning the car and still no squeal. Before that it sounded like a school bus!
Old 08-11-2008, 06:12 PM
vernon
vernon's Avatar
I would like to thank you I have a 1995 993 an the brakes are just fine also I have a 1989 mint 964. For the last eight years my breaks squeal so bad I try everthing an could not fix them!. I did what you did on your car an man does it work the squeal is now gone!!!!!! I am very happy now when I drive this car Thanks again Vernon.
Old 08-11-2008, 07:39 PM
neunneundrei
neunneundrei's Avatar
Hmmm...I'm curious - I have the big brakes on my 4S and never had a problem with squealing. I make sure that I replace the anti-squeal pads whenever I replace the brake pads and haven't had any issue.
I could understand the '89 p-car not having this, but does the '95 993 not have these pads?
Old 08-11-2008, 08:27 PM
black ice
black ice's Avatar
I put new anti-squeal spiders on all my pads and the formula for squeal disaster seems to be using certain non-OEM pads. After washing I can get 50-100 miles before squealing begins again. I'll try this formula.
Dave
Old 08-12-2008, 12:00 AM
neunneundrei
Ah, have not tried non-OEM yet. Good to know.
Old 08-12-2008, 02:30 PM
unclespeed
unclespeed's Avatar
thanks to CarreraX, I stopped using my clutch to slow the car and actually use the brakes for what their for et voila! (Virtually) no more squeal...
Got tired of cleaning my wheels daily after gettting home from work though, so now I live with it again...
Old 08-12-2008, 03:06 PM
autobonrun
autobonrun's Avatar
If this works you will have solved one of the world's last great mysteries.
Since it's made for the wheels and tires, were there any warnings on the can about getting the stuff on the pads or rotors? If not, I'll buy some on the way home.
Edit. Never mind. I tried reading for once. The ad says safe for brake components including rotors.
Old 08-12-2008, 04:21 PM
ecobb993
ecobb993's Avatar
Strange, I could only solve my squeeeel by switching BACK to Porsche OEM pads.
Old 08-12-2008, 06:16 PM
Land Jet
Land Jet's Avatar
Either you guys have race pads, which squeal a lot, or you are missing the proper spiders or backing shims, because Porsche street pads don't squeal. Squealing is caused by the vibration of the pad's backing plate rubbing against the caliper. This is the place where anti squeal shims go. Pad composition also contributes to squeal. The shims are usually removed when racing pads are used because the high heat generated by on track braking renders the shims useless. Not so with street driving brake temperatures. Check into it.
Quick Reply: YAY!! Fixed my break squeal!
