Sun roof problems
Probably dirty cables and guides. You should take out the cables and clean them and the rails they ride on. Otherwise they will break. If one of the cables breaks, it's a simple repair. The following link should be helpful:
http://www.pelicanparts.com/techarti...oof_repair.htm
You guys a great !!! This Porsche site has helped me soooooooo many times. Well the 2 screws that hold the motor together were loose.. simple fix thanks to the picture of where the motor was..
Many thanks to all you guys
Mike
Mike
Since you got your problem solved, I have a possibly related problem.
My sunroof, more often than not, has trouble during that final bit of closing where it 'folds flush" with the roof. It rolls close nice and strong, with no noise or anything, but for some reason, during that final 1% where it need to fold up flush to the roof, it gives up. If I work at it a little bit, it will finally close though. Its so annoying!
