? Re. installing Momo s/w
I could not source a resistor either... So I just built one up out of 10 and 47 ohm resistors until I got the resistance correct. You can search resistance in parralel on google, the equation is very very simple.
Then I wrapped the resesistor bundle in heat shrink.
@jdistefa
PM me your email address. I have some power point Pres with pictures of my horn harness.
Also, the 7004 wheel will not line up with the Mod 7 wheel for the horn in all directions. You have to use a cut down cotter pint to offset the horn adapter.
PM'd you...did you get it? That PP and the photos will be a big help. Again, thanks!.
Any thoughts on why the airbag light still stays on? Did the mod per instructions and checked all the resistance with meter, etc and still "blinded by the light"
thanks,
Update...CAUSE WAS TURNING KEY ON BEFORE RESISTOR WAS IN PLACE Tech turned off the light with scanner tool and it took 12 seconds.
thanks,
