993 Forum 1995-1998
Trip odometer broken
Old Jun 16, 2008 | 12:52 AM
scat's Avatar
scat
Default Trip odometer broken
Just fill it up today when I noticed that I only made 35 mi. with the last tank of gas...Something is wrong hmmmmm... I reset the trip odo drove it for a while but the indicator still shows 0000.I always reset it while the car is still but I guess everything ages and eventually stops working.So anybody experienced the same ?I am thinking in replacing the main odo gear as well since my car has 78k mi and it will fail sooner or later.Thanks!
Old Jun 16, 2008 | 10:52 AM
matt777's Avatar
matt777
There is only one gear that is prone to failure as far as I know. Are you sure that your odometer still works? I just repaired mine at 64K using the DIY instructions I found on this forum. I bought the gear from the website they recommended. It's not too hard. The most difficult part was separating the housing from the trim ring.
http://p-car.com/diy/odometer/
Old Jun 16, 2008 | 02:30 PM
Edward's Avatar
Edward
Addicted Specialist
I doubt you odo is working as it's the same gear that operates both the odo and trip odo. Yours is broken ...replace it as per Robin's site. That guy who sells the gears (Jeff, IIRC) is very helpful and answers emails practically immediately. As Matt said, simple DIY and save yourself serious dough from sending it in.
Edward
Old Jun 16, 2008 | 03:11 PM
993C4Smontreal's Avatar
993C4Smontreal
Edward
My trip and odometer work. Just the button on the trip is busted...go figure!
Old Jun 16, 2008 | 03:56 PM
matt777's Avatar
matt777
This may be fixable on a DIY basis as the mechanism can be seen when dismantling for the odometer gear change.
Old Jun 16, 2008 | 07:08 PM
Edward's Avatar
Edward
Addicted Specialist
Button, eh? Never heard that one. Let us know what the culprit is when ya find it ...I know I'm interested.
Edward
Old Jun 17, 2008 | 01:31 AM
scat's Avatar
scat
Test drove the car tonight and it looks like the odometer gear is gone.No odo/trip odo indication.Thanks for the responses! I will order a gear asap!
Old Mar 24, 2009 | 08:58 PM
dcdude's Avatar
dcdude
I have the exact same condition as Scat, the OP. All my numbers are turning just fine (for now), but the reset shaft has no effect on the trip odo.
So I probably don't "need" new gears (or just the "E15" gear from odometergears.com) but I do need to get in there to re-connect the reset shaft/button somehow, and at that point, all together now, "while I'm in there," I guess I should do at least the E15 gear.
Has anyone bothered to replace the other "16 tooth small pod" as well? It doubles the cost from $25 to $50!
BTW- I got here from the new lame search by just searching for "odometer" in the 993 board only.
Old Mar 25, 2009 | 02:07 PM
jungleboy's Avatar
jungleboy
Wow this is uncanny, this just happened to me! Talk about "johnny on the spot" scat. Speedometer workie, odometer no workie. From the look of things and what you guys are saying, it should be fairly easy fix... hopefully... I was worried about all the crap I might have had to do get this rectified. Thanks for the help everyone.
Old Mar 25, 2009 | 04:08 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Just get yourself a nice, clean, quiet spot to work with no interruptions. Suggest putting a clean towel down on work surface. Matt777 is correct...Take it nice & EZ seperating the hsg. from the trim ring. Don't rush it.
davesnothere's Avatar
davesnothere
I replaced both gears. Yes, it doubles the parts cost, but the labor cost is the same! Might as well replace both while you're in there.
- Dave
Old Mar 25, 2009 | 06:00 PM
Edward's Avatar
Edward
Addicted Specialist
- Dave
FWIW, I have never heard of anyone with the "other" gear broken. That said, I bought both because:
a)Jason said it happens, which is why he makes it
b)the part is available and just too convenient to order along with the other one
c) I don't want to "go in there" again
That was my reasoning. And yes, it is that easy, but do take your time, work carefully, and note how things are "put together" before taking it apart. Working over a clean towel is a def plus.
Edward
Edward
Old Mar 26, 2009 | 01:17 AM
scat's Avatar
scat
Changed the gear last year per instructions from p-car.com,works like a charm. Its not hard,just dont rush into it.
Old Mar 26, 2009 | 01:41 PM
Stealth 993's Avatar
Stealth 993
Mine got stuck once, I just pushed it in again, then it started to work again.
Old Mar 26, 2009 | 07:17 PM
craig001's Avatar
craig001
I had this happen in my 964. First my shop replaced the gear and of course it worked on tester and about a day after putting it back ion. Pulled it again and then was told it was the stepping motor in the speedo. At that point I just picked up a used one with close to actual milage and put it in. Here's hoping it is just the gear.
