I realize that these are relatively pointless in this day and age given that thieves will just steal the entire car now but I am need of some guidance. The PO installed wheel locks on these rims but unfortately I am no longer the owner of this adapter. I believe I lost the adpater during the suspension install updgrade and it's somewhere within the depths of my independents garage.
So, how do I get the wheel locks off and can this be acheived by a non-Porsche dealer? I don't mind taking it to the dealer but I prefer to avoid the dealer if possible. I've heard of drilling them off but I was hoping for a less invasive suggestion.
You can drill them out yourself or have a wheel shop do it. Hardware stores sell a bit that can reverse things out once the heads are stripped. Do it at your own risk though.
Make sure you check all the places your independent could have put it. Check the ashtray, doorpockets,
glovebox, toolkit and jack bag. Shortly after buying my C4 I discovered a screw in the tire. I could not
find the freaking wheel lock key. Finally I thought to look in the ashtray and sure enough, there it was.
The first thing I did was dig 4 lugnuts out of my spare parts supply and put the locks and key in a ziplok
bag and stored them.
What kind of locks are they? Do they require a socket style key?
I looked all over the car tonight. I know it's somewhere at the independents but he recently moved shops and I'm sure it's gone. It's the socket adapter type wheel lock. It's also round with teeth carved out versus the more modern engraved key style.
From what I have read here, the dealer has a master set of lock "keys". It seems to be a trial and error process to find the one that fits your locks. I recall a thread here where somebody went through this at the dealer and there are about 40 "keys" to try. You could search on wheel locks and probably find it.
Just go to the dealer to buy the right key for your wheels. They have a complete set and can find the right one and sell you a copy. IIHO this is the best route because you'll be certain of the outcome (no possible damage due to a messy drill out....remember you'll have to do it 4 times). Once you have the key you can decide if you want to keep the locks or not.
I was in the same situation when I bought my car. Mine had the factory aluminum wheel locks. It was actually very easy to do. I used a 12 point socket a little smaller than the wheel lock. I hammered it on and was able to just unscrew them one. You will drstroy the wheel locks though. When you get them unscrewed you will need to put a long screwdriver through the 3/8's drive hole in the socket to hammer out the trashed wheel lock. Sounds much harder than it actually was. I had to do this because I needed to get the wheels off and didnt have the time to get to the dealer.
110% correct on every count. They're not expensive.
BTW- The PO probably didn't install the locks as locks are OE. Unless the PO changed the locks to something else (unlikely), the dealer will have what you need. I think that there are something like 21 or 22 different keys.
I just did this when I broke my socket. (be careful if using a breaker bar....) The dealer has a complete set of 30 coded sockets, mine was #29. I could have ordered a socket for about $40 to get a # 29, but one lugnut was broken too. For $50 I got 4 new lugnuts and a new socket from Porsche. It doesn't matter what # you get because you'll gr=et 4 new locknuts with it. I had the dealer remove all 4 locknuts while I was in there, drove it home and waited 2 days for the new locknuts and socket to arrive. Very painless and didn't require chisels or drilling.
