Question about Muffler Removal / Install
I recently removed my mufflers and have a question about installing them. I did look at the DIY on pcarworkshop.
When I installed them there seems to be a bracket on the muffler itself, does this mate up to the bracket on the engine. Is this the right way to install them. The next question, is the exhaust of the muffler supposed to be lined up with the cut out on the bumper cover, or is a little off center. I do have big ovals, so I thought that the tips are supposed to angle out and follow the form of the bumper.
On a WB, the muffler exhaust pipe lines up ~35mm inboard of the rear cover center ..... this is corrected by the WB exhaust tip offset.
What tips do you have? If they look like this (see pic) with the mounting hole in the center, they are narrow body tips. They will mount up, but have to be angled out to fit, so they will not follow the bumper contour properly. Wide body tips have the mounting hole offset to one side.
