Resistors for Airbag removal
If you can't find a 3.3ohm, you can also use 3x 10ohm's in parallell.
I'm about to go downstairs and do this mod, and I have a spare 3.3ohm, and a package of 4x10ohm's.
I can mail you the leftovers for the cost of postage.
Thanks, but I would prefer not make this more complicated by putting resistors in parallel.
I am not sure about what Gert recommends, but I have the Porsche factory airbag tool and the resistor in it is Orange, White, Gold. That's 3.9 ohm.
It seems my memory has failed me a bit. I checked my old post and apparently I used a 2.7 ohm / 1 watt. A 2.8 ohm / 1/2 watt was what Gert recommended to me. You are probably correct about the testing tool, but I haven't used one, so can't confirm. I just know what was recommended, and what has worked for me. ViperBob also suggests that a 2.8 ohm works for the passenger airbag to, in THIS THREAD. Best of luck !
I just did the mod on my 968 (same as 993) and simply plugged the 3.3ohm resistor into the orange BMW airbag plug. (yes, we have BMW parts bin parts in our cars!) Tested it and it works awesome.
I still have the one 3.3ohm resistor left over, so if anyone want it, just let me know and I'll mail it - don't worry about postage i think i have enough stamps. lol.
When I installed my Sparco wheel, I tried using a 2.9 ohm resistor but the airbag light would still come on...
I went from the stock airbag wheel to the 3spoke 968CS/930S wheel.
It's possible that if you didn't do the process EXACTLY as below, it might trip the airbag light prematurely/inadvertantly, and you'll have to get it reset with the Bosch Hammer tool.
1: Disconnect the battery (and do NOT reconnect until done!)
2: Wait approx 20min
3: remove the wheel
4: install resistor (ensuring 100% contact)
5: install new wheel
6: Reconnect battery
7: Turn key to 1st detent and check for airbag light to go on and go out.
Did you switch to a 3+ohm and it worked okay?
3: remove the wheel
3: remove the wheel
I ended up re-connecting the OEM detonator piece and hiding it inside the console.
I know it's a not a good thing to have "explosives" stuffed inside the console so I'm gonna order the $30 resistor and install that instead.
If you need one of those 3.3 ohm resistors, just visit your local Radio Shack store, they should have plenty of them and at $0.99 can't really call them expensive either.
Edit: Link to wrong part removed. (Thanks to Rich for clearing it up!)
And no, I didn't buy that resistor from Rich!
When that 2.9 ohm resistor didn't work, I decided to get the $30 gizmo from airbagonoff.com as it seems it works perfectly...
