WTB: 993 Race Car
Driver Carries No Cash
One thing to consider is that PCA revamped the GT class rules and now use a Performance Index to classify cars. If I'm doing the calculations correctly, the car would be right smack in the middle of GT4 at a performance index of 707 ([2800lb weight/3.6L x 110HP/L] x 100=707. I'm not sure which cars run in GT4, but I'm guessing a stock engine with 2800lbs won't cut it too well. I don't really know.
Angus is pretty quick in it, thats for sure.
Neat idea with the biscuit in the cage - solves that issue, I am guessing.
Where are you located - Central FL?
Mark
I have been trying to build a case with the local race authorities here to make a distinction between air cooled and water cooled P-Cars for an upcoming racing series. LBS/hp does not tell the whole story as newer chassis and watercooled engines have an advantage like for like. I am guessing this is why PCA has adopted this methodology, which I find excellent.
So if my understanding is correct, for an aircooled 993TT, they divide weight by a ratio of 210 multiplied by the displacement, whereas a 996TT with the exact same weight will have a multiplier of 230..
2 EXAMPLE:
993TT : 600 HP, 3400 LBS, 3.746 LTRS. => perf. index class = 427 (GT2)
996GT2: 600HP, 3400LBS, 3.746 LTRS. => per. index class = 374 (GT1)
Is the above correct please?
Thanks and apologies again everyone.
BTW, if looking for a 993 race car, you might want to talk to Chris Cervelli here on Rennlist, it seems like he knows how to prepare really fast ones.
Hey, Jean!
Here are the new PCA rules for 2008: http://www.pca.org/clubrace/docs/200...%20Adopted.pdf
I got slightly different numbers. For the 993TT, 432 is the performance index (GT2) that I calculated using the exact 3.746 displacement that you quoted. For the 996TT, 378 is the PI (GT1. You used 230 for the HP/L; 240 is the actual number that PCA uses.) that I came up with.
PCA has definitely recognized that the newer, water-cooled turbo cars have an advantage over the air-cooled ones. Good luck with your case!
Here's one on ebay now. Not sure how much will buff out Maybe you can get the trailer with it.
http://cgi.ebay.com/ebaymotors/Cars-...m280226610678&
Yeah, I don't think $23,000 is the right price, though. That car looks like it easily needs $12,000 worth of work . . . hood, RF fender, door work, windshield, windshield frame, frame damage, tub damage, oil cooler, front bumper, splitter, grille . . .
Might be a good car for a mechanic or body shop to pick up at that price.
The pale yellow one has been for sale off/on for more than a year. When I first looked at it, the price was $55K. Not sure if he still owns it or sold it to this dealer, but Alex Felton, a very good driver w/ POC was/is the owner of this car. If I was in the market for a track dedicated 993, I certainly consider this one (pending a good PPI).
