993 Forum 1995-1998
Gear crunch
Old May 20, 2008 | 05:34 PM
allffy's Avatar
allffy
Default Gear crunch
Hi all,
I have a c2s that I bought about a month ago (pics to follow). I cant believe how amazing this car is, both to drive and just look at. It has 107k miles with a huge folder of history. No leaks and runs nice and tight. The only thing I've noticed is that from cold when I change into second I get a slight crunch, if I change very slowly no crunch. This only happens from first to second.
Should I be worried?
Old May 20, 2008 | 05:49 PM
AOW162435's Avatar
AOW162435
Seared
These transmissions are not meant for speedshifting. Take it easy during your gear changing and the transmission should prove very robust.
Andreas
Old May 20, 2008 | 05:56 PM
sigf's Avatar
sigf
Mine does the same thing when cold. I just blip the throttle a little when shifting and it slips into 2 without any effort. When warm, there is no "crunching" on mine. I don't drag people off the stoplight so I don't worry about speedshifting. Tranny shifts real nice when you're smooth.
Old May 20, 2008 | 06:06 PM
Nuff's Avatar
Nuff
Mine does this also when it's cold. I just double-clutch from first to second when it's cold. After about 5 or 10 minutes it's fine.
Old May 20, 2008 | 06:14 PM
allffy's Avatar
allffy
Thanks guys, thats put me at ease. There are so many little quirks that are normal with these cars that as a new owner the common things can freak you out.
Thanks again
Old May 20, 2008 | 07:36 PM
quasr's Avatar
quasr
I am sure we all have learned to give our 993's that pregnant pause between gears. Recently I had my transmission fluid changed and added Redline Redline 75W-90NS, which has no friction modifiers. The Redline instructions suggest adding a small amount of friction modifier but the installing garage suggest none be added. My transmission shifts "much" better now. Well worth the $.
Old May 20, 2008 | 11:14 PM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
Change the fluid -- I think you'll be surprised at the results.
Old May 20, 2008 | 11:55 PM
99three's Avatar
99three
+1 Should diminish the crunch factor.
Old May 21, 2008 | 01:38 AM
993Brendan's Avatar
993Brendan
When I got my car 4 years ago and first experienced this problem, I remember someone posted something about saying "paycheck" in between double-clutching. It stayed with me! You should be fine in 5 to 10 minutes.
Old May 21, 2008 | 06:28 AM
shamrock's Avatar
shamrock
Sorry for silly Question ..
Could someone explain the term 'double clutching'?
Old May 21, 2008 | 08:53 AM
TMc993's Avatar
TMc993
"Double clutching" is a method used to match engine and transmission RPM on downshifts. Say you're in 4th gear at the upper end of the RPM scale for 4th and you are approaching a much slower 3rd gear turn. It goes like this:
1. 4th gear - Clutch in - Shifter to neutral
2. Clutch out in neutral - Rev engine to appropriate RPM
3. Clutch in - Shift to 3rd - Clutch out
When done properly and well, all of this takes place much faster than you can read this sentence.
If you ever at a track, standing at a turn that requires hard braking, you'll hear the drivers double clutch...As they go by slowing for the turn you'll hear that marvelous "Whoop-Daaah-Whoop-Daaah" as they work down through the gears.
Terry
Old May 21, 2008 | 09:02 AM
mrsullivan's Avatar
mrsullivan
I am about to purchase some Mobil Delvac for this exact reason... I get some crunching/notchiness into third gear.
Excuse the ignorance, but how much should I order? I.E. how much do our gearboxes hold? Yes I am being lazy, I know I could look it up in the manual
thanks
Old May 21, 2008 | 09:41 AM
TAI2's Avatar
TAI2
mrsullivan: If you do a search on this topic you will find that many of us have tried a number of different trani fluids to try to improve shifting. As far as I can tell the Redline does the trick better than any other fluid. Good luck.
Old May 21, 2008 | 11:13 AM
NightFlyer's Avatar
NightFlyer
Jonathan,
Are you going to do the transmission fluid yourself or are you having a mechanic do it? I had Mayos do mine a while back but I would like to watch someone do it just to see it.
Old May 21, 2008 | 11:26 AM
Rinty's Avatar
Rinty
Default gear crunch
I used to use the double clutching up technique on my old '86 Subaru GL when it had sat overnight at - 20 C or colder. Works well. Sometimes I'd have to do it from second to third as well.
I've only had my 993 a few weeks, but I've noticed it likes "deliberate" shifts. I'm still working on getting 3 - 4 just right, but it's coming.
Rinty
