Snap, Crackle Pop on Decel
Finally got out to run my car. It is popping and backfiring a little on decel. It is a little more pronounced from higher RPM's.
It has new plugs, new ignitions wires, & a rebuilt dizzy. I checked all the wiring.
Ideas?
Ideas?
In my opinion, if it is a very slight backfire, check the alternator and fan belts tensions as a first step
the backfiring is the unburnt fuel igniting when it hits the atmosphere. the cats block the fuel, so a car with cats won't backfire.
Are you sure when you are talking about backfiring you don't mean the neat little burble you can get on rapid decel? Backfiring makes a "pop" explosion sound, the burble is, well, a burble and normal.
Have you driven it before with this exhaust setup and it *didn't* pop? Every 993 I've heard with muffler bypasses or no cats will pop and gurgle when lifting off the throttle and engine braking. It's not a real backfire (fuel igniting in the intake or whatever like carbed motors); it is what Bob said it is.
SWEET car by the way.
