Can the passenger airbag be turned off?
I have a son who is 5 years old. He could sit fine in the back seat, but he would rather be up front and see the coming corners and so on. He'd rather be where the action is.
I'm on my way to buying my first 993, and I'd like to know if I can turn off the front passenger airbag. I did a search and couldn't come up with an answer.
Also, are there any other airbags I should disable if a 40-pound kid rides in a child seat in the front?
Thanks in advance!
Matt
Thanks in advance!
Matt
Lifetime Member
Lifetime Member
The 993 does not have any factory option for a device that can turn it off, however started with the 996 there is an option you can install that can turn off the air bag.
But you do have the option of using a company that specilizes in installing an air bag turn off switch. Popular among the Ferrari owners. http://www.airbagonoff.com/
Tucker and Max
M-
T-man rides in the back, but I have been told that the airbags run through the circuit for the airbag light on the clock and by disconnecting that light it will disarm both airbags.
I also think both boys should ride to OH (if we go).
w
w
Good idea on bringing the li'l ones. I think.
(Or it could be a long day.)
Weathergirl
I wonder if a 5 y.o. in the front seat pushed all the way back and properly restrained in a booster and belt positioner wouldn't actually be safer with the airbag than without?
Think about how bad a crash would have to be for him to contact the airbag hard from that position. Then think about the tradeoffs between a broken nose and a few burns and a basal skull fracture.
Unfortunately there are so many "don't ever!" and "you must!" rules with child restraints that people aren't given enough raw information to make an informed choice about safety and comfort trade-offs.
My '97 has a factory installed air-bag deactivating buckle under the front seat. It's used to plug the factory kid seat into and it deactivates the passenger airbag.
I also found out that if I simply disconnect the buckle from a plug under the seat, it deactivates the airbag. It reactivates once pluged back in. No fault codes or airbag lights.
It was a knee jerk reaction to the kid that got decapitated by a front passenger airbag. Never-mind that the kid was unbelted and sitting on the front passenger's lap when the accident occurred.
I heard (don't know where!) that with the passenger seat in the fully rear position , you can put a rear facing child seat in without having to disengage the airbag .. anyone else know anything bout this?
