Etching with phosphoric acid: Question involves math
I'm not a person who is good with math so I would appreciate a little help.
My plan is to acid etch my concrete floor with phosphoric acid. The acid is 75% phosphoric acid. I read that I should etch using a 20% to 40% solultion.
So how much water would I need to add to get 20% and then how much water do I add to get 40% solution?
20% concentration: ~2.8qrt
40% concentration: ~1.4qrt
Edit: I had to do a damn formula on the paper to figure this out...lol!
0.75/(x+1)=0.2
=> 0.75 = 0.2x + 0.2
=> 0.2x = 0.55
=> x = 0.55*5
=> x = 2.75
Check: 0.75/3.75 = 0.2 = correct!
For every quart of the 75% acid you need water:
0.75/(x+1)=0.2
=> 0.2x = 0.55
=> x = 0.55*5
=> x = 2.75
0.75/(x+1)=0.2
=> 0.2x = 0.55
=> x = 0.55*5
=> x = 2.75
Big caution: your etching process will generate considerable toxic gas. Make sure you have very adequate ventilation!
I do where resprator mask with either acid.
