Screw rolling around somewhere in dashboard
I must have lost a screw, or other small piece of metal somewhere into the dashboard when working on the car, and now on hard cornering, I can hear it rolling from side to side.
Needless to say, this is getting really annoying. Has anyone else had this problem, and if so, what was the solution?
I have already removed the defroster vent cover to look inside, and found nothing by visual inspection, or by feeling inside with a magnet.
Thanks,
Miker
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Supercups plus cat bypass? Or maybe try putting a neodymium ring magnet on a string and dropping it into the defroster vent or behind an instrument hole.
http://www.unitednuclear.com/magnets.htm
If it's in the dash, then looking in the defroster vent won't help. They're separate. I'd pop out the tach & speedo and look around. Then just remove the dash...it's easy. The only trick is the removing the nut in the center, but since you'll already have the tach & speedo out, access will be easy.
I share your pain. I had something loose in my Lexus that sounded like a washer sliding back and forth each time I turned a corner. I finally had enough, and one day when I had all day clear, I attacked the car. First I took the entire lower dash off, then the center console, next the AC duct under the console. Under that was the carpet, which I slit enough to reveal the floor pan. Lo and behold, there was a shiny quarter, which had probably been dropped into the shifter gate by my grandson.
Maybe if you plant several magnets at various places inside the dash and then drive the car around, it may trap the offending screw--hopefully it is ferrous...
I have the same screw (or other obect) rolling back and forth in my dash...as a matter of fact, if you listen closely, you can hear it going from side to side on some of my track vids. While my car is apart, I hope to find it and put it to its certain death.
I had a similar problem,IT DROVE ME CRAZY pulled both seats and found over a buck and a half around and under the electrical components, you also need to check inside the rails that the seats mount to (I put it all back together and still had one nickel in there that I didn't see the first time) It's quiet now
