Need 2nd Opinion on Fuel Pump Issue
)My car died while driving yesterday. I pulled the DME and made sure contacts were clean. It looks pretty new but I have not replaced it or gotten a spare yet (I know, I know...)
I checked the fuel pump fuse and it was blown. I put it in a spare and the car started and drove about 100ft. before dying again. I checked the fuse and it was blown again.
I suspect the fuel pump has gone bad and shorted out. It has been a little loud since I got the car and the PO records indicate small bits of metal in the fuel filter at 90K service - indicating that the pump was on it's way out. The car now has 106K miles.
So, everything lines up that it's the pump but thought I would run it by this group first before buying a new one.
Also, I haven't yet looked at any of my repair info but was wondering if the pump is underneath or inside the trunk area.
Thanks guys!
David
The fuel pump's location is under the passenger footwell accessible from under the car.
There is a rectangular flap door held by several 10 mm nuts.
A reasonable price for the pump is on the auction site.
In the trap, there is the pump, a small hose, and the gas tank filter.
the fuel filter starts at a height of about 3 to 4 inches from the bottom low of the gas tank.
So if you think of any metal pieces left, you have to remove the gas tank for that.
Remember that you will have to empty the gas to replace pump.
The small rubber hose connecting the pump to the tank can be stuck from age, and is expensive to replace.
Put some grease on the electric connections after bolting the new pump.
So, back to my original question... It seems as though you would all agree that the pump is bad.
I suppose if it sounds like a duck, looks like a duck, must be a duck (or pump), right?
Do you know if you always let the gas tank run low before you refuel it? Or has the car ever ran out of gas before? Fuel pumps were designed to pump liquid (gasoline), they could easily burn out if it was sucking air when the gas tank is almost empty.
http://p-car.com/diy/ac/
Yes, the fuel line comes on periodically so that could have accelerated the pump wear. Plus, according to the records (and noise), the pump has already been on it's way out for the entire 14K miles I've driven it so far!
2 - On the BMW, the pump is actually submersed inside the gas tank. Cooling for the pump is provided by the gasoline. Many people suggest that by letting your tank get empty between fill-ups, you subject the pump to "lack of cooling" due to the lack of gas in the tank...thus causing premature pump failure. In the case of the BMW, I don't believe this to be true, as the pump is fitted into a "trough" at the bottom of the tank, and this trough always has gas in it...unless you are down to about the last cup or less of gas...otherwise, the pump is fully submersed in gas.
Item 2 probably doesn't apply to the 993, but item 1 probably does.
