993 Kinematic toe rear adjustment question
Dear Rennlisters
I was changing the oil on my 1996 993 Carrera and looking from the rear noticed that the area around the driver side Toe in eccentric adjustment bolt where it passes through the sub-frame looks burnished as if the bolt moves as the car is driven.
Does anyone know if this bolt should move in the sub frame or is it just loose.
Andy
Andy
The bolt should not move, it should be tight. Should be torqued to 85Nm
