Piping between front bumper and wing by headlamp
Has anybody changed these short items of black plastic? Did you have to remove the entire front PU or is it possible to do side by side (ie one-handed)?
Any advice gratefully received!
Yes , ordered them from OPC ,but they are made of rubber and are a nightmare to do,but look good when done I have a mate who runs a body shop and I had done the stone chips then I gave him a hand ,WE Had to do them twice, I also did the ones between the top of the wings and windscreen ,why are you doing them
At some point the PU was repainted and both seals appear to have been pushed down below the surface.
I've found the p-car item on removing the whole bumper, but that's a step too far, so to speak!
A caution to anyone planning to do a bumper re-spray...
You should order this rubber seal in advance of removing the bumper and replace it as a matter of course. When you remove the original, it is almost impossible not to stretch it at some point and putting it back in place so that it looks correct is next to impossible if you stretch the seal.
I wasn't aware of this and had to re-use my original seal. It looks like crap and I'm going to have to do it over eventually.
This is another example of Porsche staying with a 1950's solution to a problem other carmakers solved long ago...
Terry
Terry
