LPMM review
Seared
The shields are from my original mufflers. I found a spare set of cans (without shields) on Ebay and sent those to Darin. After modifying the shields, I primed and painted with high-temp paint.
Andreas
Andreas
Location: 40 min South from the 'Ring, 45 min East of Spa
Excellent Work!
I currently have the one and only Leland Pate creating the first ever LPMM 987 v.1 right now for my car:
http://farm3.static.flickr.com/2085/...6024d9e187.jpg
I'm trying to get him to expand his handy work to other model series
Andreas, those look incredible! I'm glad you like the sound!
Seared
I also had Darin do my cans and couldnt be happier!!! The sound is perfect! Darin, Im trying to talk my buddy into having you do his 997s. will the sound be similar to my 993 or do you have a sound clip?
I don't think any exhaust change will buy you much more performance on a 993. If you drill out your airbox (more air in) and do this mod (more air out), I think it is an improvement.
Cactus, they should be there Friday...hang in there, buddy!
I have not given up, and will continue to work on the "turbo solution".
I'm Still Jenny
Charlie, I did try this bypass to a set of turbo mufflers, but the result was not as I hoped. The idle sound was too "boaty"...blub, blub, blub, blub......and on accelleration, the turbos sucked all of the sound out (they were very quiet).
I have not given up, and will continue to work on the "turbo solution".![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
