question- Turbo S Brake Duct Fog Light BULBS
part number
email alan
alan@aceparts.com
....he is a 993 owner so he will know exactly what you want.
Later on, I got a little bit cheeky with mine, I bent my flanges and added the next sized bulb [seeing as heat is not an issue]
They are so bright, I use them daytime running lights
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
email alan
alan@aceparts.com
7th Gear
I had the same issue, I was looking for a bright white replacement for the little 5w marker light after I installed the factory turbo S air ducts. You also lose your fog lights when going with the air ducts. So, I found these http://www.superbrightleds.com/specs/festoonhp.htm So far, I love them, super bright and fit in the same connector tabs as the new marker lights, they are 37mm long just like the 5w bulbs. Go with the 3710-WHP6, they are about $15 each but well worth it. I also moved the marker lights over to the connectors that used to run the fog lights, so I can turn them on and off from the fog light switch. Hope this helps....Paul
https://www.superbrightleds.com/more...car/2160/4949/
