993 Forum 1995-1998
Shifter Boot Replacement
Old Feb 7, 2008 | 10:41 PM
Hank's Avatar
Hank
Default Shifter Boot Replacement
I searched and found nothing, which leads me to believe its terribly simple, and thus Im almost hesitant to ask......but. I got a new shifter boot and rather than go prying around trying to figure out how it comes off, does anybody know the steps to replace this item?
many thanks in advance.
Old Feb 7, 2008 | 11:05 PM
Novice's Avatar
Novice
push down along the left hand side of where the boot meets the plastic console.
There are two metal clips (both on the left) that are holding the metal wire frame of the boot. Once you get that side off, the rests are very obvious. Install is opposite of the removal process.
Old Feb 8, 2008 | 03:26 AM
993_Pilot's Avatar
993_Pilot
Try HERE from the DIY on P-Car with pics.
Old Feb 29, 2024 | 05:48 PM
kkswow12's Avatar
kkswow12
i don't know if this will have anyone looking at it 16 years on, but does the question not get asked then, maybe a new thread...i must now remove the shifter leather/****/boot all the way, rosanna!, yeah, and replace with a new one... do i just yank 'er up and off, or is ther a twist involved, or...sure i'll figure it out... but so far great info....many thanks if any of y'#all are still around...even if you're not...
Old Feb 29, 2024 | 07:18 PM
71-3.0-911's Avatar
71-3.0-911
If it's the stock ****, remove the skirt and pull straight up... with force.
Old Feb 29, 2024 | 08:13 PM
kkswow12's Avatar
kkswow12
it is.... and i will, thanks
Old Mar 1, 2024 | 01:32 AM
mike cap's Avatar
mike cap
With “force” is the operative word. Be careful not to hit yourself in the face. Ask me how I know.
Old Mar 1, 2024 | 04:33 AM
TakeFour's Avatar
TakeFour
If its a 4WD it will have a clip that needs to be removed first!
