993 Forum 1995-1998
ANYTHING NEW ON THE MOBIL 1 FRONT?
Old 10-20-2008, 09:24 AM
  #376
Charles Navarro
Charles Navarro's Avatar
Received 1,200 Likes on 620 Posts
The Castrol TWS I had here recently for a customer was SJ rated (say 6 months ago), if that's worth anything. I'm familiar with the other variants, but have never seen nor used them.
Old 10-20-2008, 10:07 AM
  #377
NC TRACKRAT
NC TRACKRAT's Avatar
I'm blending Brad Penn 10W30 and 20W50 to get an effective 15W40. Less expensive than synthetics and the proper ZDDP additives.
Old 10-21-2008, 04:02 PM
  #378
s2racer
s2racer's Avatar
i assume this thread was reinvigorated due to the article about updates from porsche regarding recommended oils. am i correct the consensus here believes (regardless of the porsche factory recommendations) that 0w40 mobil1 should probably NOT be used unless in very warm areas (like FLA, TX maybe?).
Old 10-21-2008, 04:43 PM
  #379
993Maineiac
993Maineiac's Avatar
I'm about as far south as one can get (and FWIW I went to high school in St Pete) and am sticking with the Brad Penn racing oil. It did a good job this summer.
Old 10-21-2008, 08:28 PM
  #380
DJF1
DJF1's Avatar
I think you got it backwards... 0-40 could be used in very cold climates as its thinner oil which helps in very cold temperatures. Personally I stick with the Mobil 1 15-50 even in the winter, although my cars will not be driven in sub zero temps.
Old 10-21-2008, 09:19 PM
  #381
s2racer
s2racer's Avatar
oops....i do have it bassakwards. anyway, the article in panorama says the factory is now saying m1 0w40 (along w/helix ultra 5w40) is the approved oil for 95-98 993s. most confusing.
Old 10-21-2008, 10:47 PM
  #382
NC TRACKRAT
I'm looking at this differently. Weight/viscosity v. temperature is one factor but, more importantly, the additive package is another. We're talking about 10+ year-old vehicles here and Porsche has to recommend oils that are in keeping with the politically correct thing to do. Respected engineers and engine builders warn that, without the proper additive packages, premature wear will occur in older engines that required them. Our vehicles are out of warranty, hence, it's up to us to make an informed decision.
Old 10-22-2008, 05:22 PM
  #383
Slow Guy
Slow Guy's Avatar
If your concern is sticking to a Porsche approved oil I would not go below the 5w40's, and there are several brands on Porsche's recommended list in the 5w40 weight. As Steve and Charles have stated previously the 0w oils are just too thin for our 993's.
Personally I would stick with Steve and Charles' recommendations of (I think) 15w40 or higher but if you want to stay within Porsche's recommendations don't go below the 5w40. JMHO
Old 10-22-2008, 05:32 PM
  #384
matt777
matt777's Avatar
I've never run 0W oils in any of my vehicles and temps get down to -40C here so I have no idea why 0W40 would be recommended
Old 11-03-2008, 08:14 PM
  #385
ThunderC4S
ThunderC4S's Avatar
This oil is only $2.59.
I am staying with Mobil 1 15W-50.
Old 11-04-2008, 07:55 PM
  #386
fullbooker
fullbooker's Avatar
Yeah, and its only 20 oz.
Phil
Old 11-04-2008, 10:45 PM
  #387
Pan58
Pan58's Avatar
I use AMSOIL in all my cars , trucks, and bikes
Old 11-05-2008, 12:52 PM
  #388
GaryB
GaryB's Avatar
I just had my oil and filters changed by John Walker in Seattle (it could almost be a museum with all the stuff he's gathered over the years). He recommended Mobil1 15-50 with half a bottle of Comp Cam. Comp Can appears to have additional ZDDP, he said "the whole bottle would be too much".
Gary
Old 11-05-2008, 01:54 PM
  #389
2Many Cars
2Many Cars's Avatar
Has anyone tried this:
http://www.redlineoil.com/products_m...1&categoryID=1
I have a couple of racing friends who are big fans of Redline stuff.
Old 11-07-2008, 01:25 PM
  #390
Carrera Mike
Carrera Mike's Avatar
Cool
http://www.mobiloil.com/USA-English/...ing_0W-30.aspx
Mobil 1 Racing 0W-30 is specifically designed to maximize horsepower during race conditions. Mobil 1 Racing 0W-30 is a very versatile racing oil developed for a wide variety of race engines and racing applications.
Mobil 1 fully synthetic race-proven technology is engineered to deliver performance and protection for some of the most demanding race conditions, include circle track, drag, sprint and road racing.
Both Mobil 1 Racing oil viscosities:
Offer boosted levels of anti-wear protection (nominal phosphorus level of 1800 ppm) well beyond those of typical automotive engine oils.
Are recommended for a wide range of race engine applications, including highly loaded flat tappet designs.
Provide exceptional high-temperature protection in high rpm engine operation, even at temperatures up to 400°F (204°C).
Mobil 1 Racing oils are not recommended for street use.
Quick Reply: ANYTHING NEW ON THE MOBIL 1 FRONT?
